does anyone know if inventables is workin or gonna work on single line text
oh could that be done by setting the cut path to on path?
Yep.
When I’ve done that using a TT font rather than a single line font, the bit follows both lines which can be problematic if you’re doing something with small text. I had to change to a single line font to get a clear carve. I’m using VCarve. Does Easel treat fonts differently?
