Hello everyone,I am new to X Carve and recently i assembled an X Carve .My problem is that when i carve any object the actual output comes out 4 times bigger on all axis i.e if i put value on Z axis =3 mm it will cut 12 mm…1 mm on X axis will cut 42 mm and 1 mm on Y axis will cut around 42 mm,This is creating a lot of problem as i am not able carve desired size.Mine is 1000 mm rail size x carve,grbl values are as follows
Grbl 1.0c [’$’ for help]
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000011)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$20=0 (soft limits, bool)
$21=0 (hard limits, bool)
$22=0 (homing cycle, bool)
$30=12000. (rpm max)
$31=0. (rpm min)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.947 (z, step/mm)
$130=740.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
ok
