Sizeof route different than set numbers
Set up a guitar route and the routings measure 2 mm less then numbers programmed what is causing this.
Need more input. Sharing the project in Easel is good.
Machine calibrated? (Does it jog 250mm if a 250mm jog command is given)
End mill true in size?
Backlash?
System flex / lack of rigidity?
Work flow error? (Conversion issue or cut set to follow path vs inside/outside cut)
That crossed my mind I believe Im set to cut on path. This is my first try at the CNC thing.
Outlines such as that are usually set to cut outside of path.
Pickup routes set to inside path?
