It would be great to be able to “snap” objects to different objects or a grid 1”, 1/2”, 1/4”, 1/8” etc. or to different edges within the work area.
aligning objects to one another is a function already, and they tried the grid one before and that caused other issues with the way it was released in the past, so much of a problem with the other items that they immediately reverted back and haven’t released a new version with the grid snapping yet, I think that was over a year ago that the prior one was released for a few days…
As to how to aligning to other objects, you’d want to “Lock” the main “Parent” object that you don’t intend to move. then select both the Parent object and the “Child” object (the object that you do want to move) and use the alignment buttons at the top, which are also found in the right click menu.
These alignment buttons only appear when multiple design elements are selected at the same time.
