Just signed up to be notified when it releases. Cant wait.
I finally saved up enough money to get a 1000mm X-carve. I want to purchase it with the X-controller so should I wait until the x-controllers available and order all at once. Or could I get the X-carve minus the current motion controller kit and power supply and then just get the X controller when it comes out? Is there going to be a bundle savings on the X-controller? My thought is that I can get started building the x-carve, and itâs table while I am waiting for the X-controller to become available.
The X-Controller will be an option for X-Carve. We donât know when it will be available. We are a little frustrated with our extruder on this project. We received sample extrusions off the tool that were perfect, but production parts are still in process.
Here is a another teaser photo of the inside of a unit with the sample extrusions.
As you can see, it has a massive heatsink. It is a bit overkill, but this plus the fan means you can run full current without worries⌠Just donât smoke the motors now
That little loopback connector with the red wire allows us to test without the E-stop when the cover is not installed.
I would buy this in a second.
â˘Built in Grbl CNC Controller
Is the built in controller an Arduino Uno, or something else?
ThanksâŚ
Larry
I bet it is based on the Arduino, but it looks to be 1 board so it probably closer resembles the TinyG
The goal on this one was to have it 100% grbl compatible. You can see a âPowered by Grblâ logo in the corner if you look carefully. With that said, donât be surprised if grbl reveals some new tricks with this product
please be native pendant control. please be native pendant control. please be native pendant control.
Grbl is unlikely to have a complex pendant. It currently has three pendant like functions.
- Cycle Start
- Feedhold
- Grbl Reset
There is a connector on the X-Controller to access those and we plan to âexploitâ that in the future. These features are also accessible via software and can be very useful. Feedhold is actually faster than an E-stop because of capacitance in the power supply. E-Stop is safer in the true emergency.
Grbl Reset is an advanced feature that many people donât understand. If you feedhold a job because a bit broke, you can clear the planner and restart a job a little before where the bit broke. The machine will not loose itâs place between jobs.
The way to do a full featured pendant is through the Gcode sender (Easel, Chilipeppr, UGS). A simple one could be made with an Arduino Leonardo as a keystroke sender. Chilipeppr has an awesome one using the Shuttle XPress.
Stupid question: What is âa complex pendantâ and ânative pendant controlâ?
I donât think those have formal definitions. Here was my take on them.
- Complex Pendant. This is a pendant that can do advanced thing like jog the machine and zero work offsets.
- Native Pendant: A pendant that plugs directly into the X-Controller?
A boy can still dream. Iâve actually made a Start/Hold/Reset pendant for my rig already, and as soon as I find the USB keypad I have around here somewhere, Iâm going to try that out as a control pendant. Funny you mentioned the Leonardo though - I have one in my Box-O-Arduino stuff, and I may just have to dig it out and play around a little bit.
@NAM37 - by ânative,â I meant the ability to somehow plug in a control pendant and have it Just Work⢠without fiddling around with the aforementioned options.
Will there be a Z probe accessory or touch plate available from inventables to bundle with the new X-Controller
Niiiiiice! I might have to borrow this idea!
@DarcyBertolo The X-Controller has the connection and we have a touch probe that looks like this.
Rather than a plate, we use a brass âpuckâ
Any update
I was waiting too, then I decided to go ahead and order just the x-carve minus the motion control and power stuff. I figured I can start building the x-carve and add my modifications in the meantime, then just order the x-controller the moment it is available. I just hope itâs available soon. Iâll end up paying more in shipping but I am sure there will be other parts Iâll need to order anyway. Looking forward to x-controller!
Two questions
Would there be any problems to mounting the X-Controller upside down on the underside of a table, over heating or such?
Could the emergency stop button be relocated away from the X-Carve?
