I am using the J Tech Photonics GRBL version 0.9g firmware, and I’m having some trouble getting my 1000mm machine to behave correctly after the homing cycle. I have the homing switches sold by inventables. After homing the machine using UGS, the tool is at -789,-789, 1 machine coordinates and 0, 0, 0 work coordinates. Jogging after homing results in fractional movements. Before homing, entering 40 as the step size in UGS will result in a 40mm movement in X and Y. In UGS, selecting “Return to Zero” sends the tool RACING to the opposite corner (positive x, y) of the work area; I have to kill the power before it crashes! Very scary! Likewise, “Reset to Zero” in UGS says that it is not a supported function.
I’m just getting the machine setup, and I can connect to my machine/grbl using Ubuntu and a Windows 7 computer. However, I cannot, under any configuration or version of GRBL, connect the machine to Easel. I’m looking for a third computer to test.
So, what am I doing wrong or not understanding about initial machine software setup?
I’m using the following settings in GRBL:
$0=10 (step pulse, usec)
$3=3 (dir port invert mask:00000110)
$6=0 (probe pin invert, bool)
$10=3 (status report mask:00000011)
$12=0.002 (arc tolerance, mm)
$13=0 (report inches, bool)
$14=1 (auto start, bool)
$20=1 (soft limits, bool)
$21=0 (hard limits, bool)
$22=1 (homing cycle, bool)
$23=3 (homing dir invert mask:00000000)
$100=40.000 (x, step/mm)
$101=40.000 (y, step/mm)
$102=188.976 (z, step/mm)
$130=790.000 (x max travel, mm)
$131=790.000 (y max travel, mm)
$N1=F4000 (Default Feedrate)
