I am looking to sell my X-Carve, I am seldom home to use it. Specs are as follows:
X-Carve 2015 X-Carve Core Components X-Carve 1000mm Rail Kit Black MakerSlide, support extrusions, GT2 belts, brackets and hardware X-Carve ACME Lead Screw Kit ACME lead screw, Delrin nut and hex nut X-Carve 1000mm Waste Board Kit Waste board with threaded inserts and hardware (clamps not included) X-Carve NEMA 23 Stepper Motor Kit Four 140oz-in stepper motors, pulleys, hardware X-Carve 110V DeWalt 611 Spindle and Mount DeWalt 611 spindle (US voltages only), mount and hardware; we do not carry the 240V version (D26200) X-Carve Arduino/gShield Motion Controller Kit Arduino, gShield, enclosure, fan, USB cable, wire, hardware X-Carve Power Supply Kit 24V / 16.7A / 400W Power supply, interface PCB, power cord and hardware X-Carve 1000mm Wiring Kit Cable, terminal blocks, hardware X-Carve 1000mm Drag Chain Kit Drag chain, mounting brackets, hardware X-Carve Limit Switch Kit Switches, wire and hardware X-Carve Tool Kit Tools for assembly, including various wrenches, screwdrivers and safety glasses, all in a durable pouch 1/8" Precision Collet Kit for DeWalt 611 1/8" precision-grade collet, nut and wrench (allows you to use 1/8" shank bits with the DeWalt 611 for precision cutting) X-Carve Clamp Set Secure material to the waste board while carving High Speed Steel 2 Flute Upcut Spiral Onsrud-brand bit with 1/4" shank and cutting diameter for cutting woods and soft metals Solid Carbide 2 Flute Spiral Upcut (Ball Nose End) Cutting Diameter: 1/8 in, Cutting Length: 1/2 in, Shank Diameter: 1/4 in, Overall Length: 2 in, Material: Solid Carbide, Type 1: Upcut, Onsrud Part #: 52-240B, Cutting Material 1: Plastic, Cutting Material 2: Wood, Cutting Material 3: Plywood, Cutting Material 4: Corian, Cutting Material 5: Aluminum, Type 2: Ball nose, Use: Three-dimensional contouring X-Carve Digital Calipers Measure the exact thickness of the material you’re carving VCarve Pro CAM Software - $174 machine bundle discount (reg. price: $699); not Mac-compatible
I am asking $1750 obo, could be shipped partially assembled. Pictures upon request.
