Hello everyone.
Do I have a question, when I do the gcode on solidcam, which machine do I choose to be compatible with easel?
thank you very much to all
If you can add your own post processor you could model it after one of these:
We also publish the Easel gcode spec
https://inventables.desk.com/customer/portal/articles/2258567-easel-g-code-spec
If Fanuc gcode is listed you can also try that.
Hi zach.
Thank you very much for answering.
I will deal with fanuc.
I can not install post processor.
Then I publish if it goes well with fanuc.
I’m having the same problem with SolidCam. I tried to download the post processor you linked, but it doesn’t seem to exist.
As for using Fanuc, there are 4 different flavors. I was hoping you could hep me out selecting which one.
Fanuc10M
Fanuc11M
Fanuc16M
FanucOM
Thanks
