Hi All,
As subject. I create some text using a 1 stroke font in the Hershey text extension. Then select all and SHIFT + CTRL + C to convert to a path then save as SVG.
In Easel, it starts to import the SVG but stops about a third of the way in then locks up.
Any ideas please?
Cheers
Ian
I think that problem is usually caused by having empty paths. It is a bug we have needed to fix for a while. Check your svg file for a path where
... d="" ...
The ‘d’ is the path string, and if it is empty, Easel will fail importing it.
Remove any <path>
element that has an empty path string.
Excellent, thank you very much Paul, I’ll give it a try shortly.
The couple times I’ve encountered this issue I’ve used this web based SVG “cleaner” to fix up the file.
https://jakearchibald.github.io/svgomg/
Sorted. That was exactly the problem, a few empty paths
That tool you linked is brilliant, added to my toolbox.
Cheers
Ian
