[solved] Easel only showing 11x11 material
Hi everyone, does anyone have any clue how I can change my Easel layout from 11X11"? I am cutting acrylic, i went in and set the acrylic for .220 depth and 18X24" and it still shows 11x11" my project runs off the board. Any ideas? Thanks!
What size machine do you have and what size measurements are set up under the machine tab in the work area section?
Click on the “Materials” menu item, that’s where you can set the size of your workpiece.
Thanks Brian That did it! It was set to the smaller machine! You guys are great!
For some reason my machine was setup wrong. I changed it and it all works! Thanks
Anytime, glad I could help
