I’ve been able to solve my issue. Please read through the posts to understand the issue.
I’ve read through some posts about squaring the bit. I’ve decided to go the “credit card shim” route. I’ve found that in order to get my bit square I need 4 credit card thicknesses to get close… within 0.5° of square.
So now that I’ve placed the shims in there the bolts aren’t long enough. No worry, I’ll head to the hardware store and get longer ones.
The thing is… why is my X-carve so out of square to begin with? Is there somewhere else I should be looking? I’ve searched the forum for answers and that’s how I found the credit card shim thing. Is that all I can do?
You can see my issue in the photo really (I think). It looks like the X-carriage is rotated on the X-rails. Like it’s clocked a bit counter clockwise in the view I took. Would an assembly mixup throw it off that much? That’s where I’ll start my reassembly.
What x rail do you have currently ? One piece or two? I had problems like this from my original two pieces rail twisting I never could get it really square
Have you checked squareness on multiple spots on the wasteboard? I remember seeing somebody having to shim the wasteboard up because it Sat lower than other parts…
Look at your V-wheels. Are you missing a shim washer between the bottom V-wheel and the X carriage? Looks like there is one on the top wheels. Can’t see the bottom clearly.
I solved my issue with squaring the bit. As some, including myself, assumed, I assembled the X-carriage V-wheels incorrectly! Some of the V-wheels were missing the washers! Not sure how I did that but, I did that.
I’m going to work on dialing it in some more but it’s definitely in the ballpark now. Just some tweaking here and there and it’ll be golden.
Thanks for all the tips and tricks everyone. Hopefully this helps someone that’s dealing with the same issue.
