Hi guys… I just started using UGS recently and when I open the program the window is super small. I need reading glasses to see it. No kidding.
Any ideas how to make it normal?
Java 7 and 8 don’t have good support for HiDPI screens. You can upgrade to an early release version of Java 9, or switch to the platform version of UGS to fix it.
Windows 10 machine:
Find java.exe you installed.
Right click -> Properties
Go to Compatibility tab
Check Override high DPI scaling behavior.
Scaling performed by: choose System
That worked! Thank you!
I’m like Tyrion Lannister. I drink and I know things
Didn’t say I know things while drinking… we may be more alike than you think
Hi Jeremy - i have the same problem. But if i change the settings, the ugs window didn’t change. I already reinstalled the jave. What version do you use? THX a lot,…
I leave this here since I had the same problem and this solution didnt worked for me. The problem was I was modifing the wrong properties, this was the solution. (step by step for those not familiar with windows)
Operating System: Windows 10 64
Laptop: Dell Inspiron 17 - 4K resolution
UGS zip file: ugs-Platform-app-2.0-Snapshot (night build)
Java zip: jre-8u251-windows-x64
