(SOLVED) X-Carve Keeps Going Idle?
Hi, new X-Carve user here; I have been super excited to use this product, but can’t seem to get a full job to finish…
I have tried several different jobs, from several different sites, even a couple of my own F360 creations. I can load up the Gcode (in chilipeppr, easel, or UGS) and the job starts as if everything is fine, homing goes smoothly, there seems to be no problem. I have never been able to finish a job, however; because at random times within each job the X-Carve just stops. nothing crashes, the software continues to work, but the X-Carve goes idle and becomes unresponsive.
I have checked the baud, it is 115,200 on my computer and in each of the gcode sender programs I have used.
Please advise, and thank you.
Best,
JM
Check this out:
Thank you for the quick response; I have unchecked all my root hubs and I will respond on whether my X-Carve finishes its job or not!
Erik, you are a saint; I left my X-Carve running for an hour by itself and came back to a job finished!!
I cannot thank you enough!
Best,
JM
Glad to hear it!
