OK, when i went there and tried to copy, I clicked the “show status” check-box. I guess I’m in an “Alarm” state?
$132=-0.000 (z max travel, mm)
$131=290.000 (y max travel, mm)
$130=290.000 (x max travel, mm)
$122=0.000 (z accel, mm/sec^2)
$121=-58162.952 (y accel, mm/sec^2)
$120=0.000 (x accel, mm/sec^2)
$112=-2147483.648 (z max rate, mm/min)
$111=0.000 (y max rate, mm/min)
$110=0.000 (x max rate, mm/min)
$102=320.000 (z, step/mm)
$101=40.000 (y, step/mm)
$100=40.000 (x, step/mm)
$31=0. (rpm min)
$30=1. (rpm max)
$27=2147483.648 (homing pull-off, mm)
$26=255 (homing debounce, msec)
$25=2147483.648 (homing seek, mm/min)
$24=2147483.648 (homing feed, mm/min)
$23=255 (homing dir invert mask:11111111)
$22=1 (homing cycle, bool)
$21=1 (hard limits, bool)
$20=1 (soft limits, bool)
$13=1 (report inches, bool)
$12=2147483.648 (arc tolerance, mm)
$11=2147483.648 (junction deviation, mm)
$10=115 (status report mask:01110011)
$6=1 (probe pin invert, bool)
$5=1 (limit pins invert, bool)
$4=1 (step enable invert, bool)
$3=63 (dir port invert mask:00111111)
$2=128 (step port invert mask:10000000)
$0=0 (step pulse, usec)
Alarm:
<Alarm,MPos:0.0000,0.0000,0.0000,WPos:-3.8000,10.8000,0.5000,Pin:111|1|0000>
