[Solved] Z axis move irratic - (reason wires were loose)
I have put probably 12 hours on my X carve so far and now a new problem arrived
IF i am in Easle and trying to lower my Z axes i push the down button then it moves down .1 like expected the next time i push down it moves up .1… sometimes it moves down 2x then up 1ce ect but there seems to be no rhyme or reason why…
I have restarted my PC and arduino any other ideas???
you need to check your connections. something is loose wiring wise on your z axis.
You were 100% correct they came loose at the motor contol board
Thank you
No worries glad I could help
