Specifying bits to use
Can you specify in Easel Pro what bit to cut a certain line? Or does each element with different bits used, have to be put on a different page?
As it is now, the answer is ‘no’ you cannot dictate what parts will be cut with which bit in a 2-part carve.
The work-around is to duplicate your project and make the cuts as two separate processes.
There has been much talk about adding this feature - and MANY of us WANT it - but I do not know where it is in the que for improvements to Easel (along with allowing multiple bits rather than just two).
