Spindle Mount for 80mm VFD Spindle (STL attached)
I used Chris Meyers’ list. There are 20 holes in the 1000 open rail so you will need 80 inserts and screws. I ordered a ton of their excentric spacers as well - they are much more robust. I did NOT order their v-wheels - which are supposedely more robust but I re-used the x-carve wheels because I have lots of extras:
4 - Open Rail 1000mm $24
http://openbuildspartstore.com/openrail-linear-rail/26
8 - 3mm Aluminium Spacers $1.20
http://openbuildspartstore.com/aluminum-spacers/8
4 - 6mm Eccentric Spacers $8.00
http://openbuildspartstore.com/eccentric-spacer/11
4 - Low Profile M5 -8mm Screws (25 pack) $12.60
http://openbuildspartstore.com/low-profile-screws-m5/5
4 - Tee Nuts (25 pack) $19.80
http://openbuildspartstore.com/tee-nuts-25-pack/6
1 - 40x40 VSlot Linear Rail 1000mm $20.00
http://openbuildspartstore.com/v-slot-40x40-linear-rail/19
The axel approach to the v-wheels has a big impact as well - you will need M5 threaded rod and four nylock nuts per axle plus washers. The spacers mentioned above had the v-wheels dead center on each rail so, it appears to be a good list.
