I have a comgrow 30x18 everything works but spindle won’t run
Make sure the spindle type is set correctly. Go to machine>edit machine and set spindle to “hardware” control and the type to “other” that should get it going
Not sure if you have this sorted out yet but that’s the machine I started on. There are a couple switches on the side of the controller that need to be put in the correct position. I mean the controller that’s mounted to the back of the gantry, not the little hand held controller with the screen.
