I’m having an issue with my X-Carve and the z depth of the spindle changing during the cut.
The first tool path will start and it will cut directly into the material. However once it is finished with the cut and moves onto the second tool path line, the spindle is now around 0.5" or so above the material now completing the tool path line up in the air.
There may be a general z-depth issue because the first tool path is set to cut all the way through and it doesn’t.
I’ve tried both using both manual and z-probe as well as different files and just trying to text tool and it does it every time.
Any help would be great!
