how do you change the spindle speed i have a 500watt spindle i think it should spin at 12000 rpm but only spins at 1000 how do i fix that
more info, are you using a VFD? type of machine
I’m new to this so i don’t know what you mean by VFD
post some pictures of what you have?
What is the $30 and $31 setting on your cnc?
Is this spindle speed controlled by gcode or by a knob. Many 500w are manually controlled by a knob and need to be adjusted by hand…
and if you wonder what the actual RPM is then you need a tachometer. I bought me a cheap one on Amazon. Check it out:
thanks i’m got one on order
by the way thanks for all the help. i learned a lot
