Hello everyone, my question is the following: in the Easel Free version there is the possibility to manually adjust the spindle speed.
Are you asking if a person can adjust the spindle speed during a carve? The answer to that is no…
If your machine has the ability to activate and deactivate the spindle, you can set the Spindle Control to be controlled by Easel and the hardware. When the gcode is generated, Easel will insert the appropriate M3 & M5 codes along with the RPM setting.
Does that answer your question?
{:0)
Brandon Parker
