Was wondering if I start carving a project can I pause it, unplug my laptop and continue another day?
If you pause it you will need to leave everything up and running. If you turn anything off you will end up having to start all over again.
Ok, so what do you do with projects that take several hours
You leave everything running and hope the power does not go out. You can in some cases white out what has already been carved and start over so it will not carve the first part out. Just depends on what you are carving.
Thank you
Or split up the big project into smaller segments, and run them in sequence as seen fit.
With homing switches installed you can have a repeatable machine/work space syncronization (within the precision of your machine/switch)
