Hello,
I am using a maslow machine and the starting position is the center of the plywood sheet. I am trying to generate the code from easel. I read the post there which is to run form a different posotion from the lower left but it is only when running the machine directly from easel (or I did not understand it properly) Carving from the Center – Inventables
I also tried to go into shape an set “center” but I have many shapes and it does not look like it modifies anything (the preview of the cutting path still start from the lower left corner).
Anything I am doing wrong and is it possible to generate the Gcode starting from the center?
Thank you for your help
Alexandre Bessy
