Starting run from center of material instead of bottom left corner
Is there any way to set home at the center of the material and have the image cut from there? I have some odd shaped natural wood pieces and would like to run from center out.
Yup you can, it’s a little counter-initiative but see the post below:
Gotcha. It will just look crazy in Easel. But, if the bit is centered in the material it will run fine. Running another part now but will test as soon as its done. Thank You…
Did the test run using an Easel icon. Worked perfectly. Thank you for the help.
Awesome! Glad to hear it worked out for you!
