Hi, it looks like people have modified their X-Carve to use a dremel in place of the spindle. I think they used the X-Carve itself to do the modification, though, which presents a bit of a chicken-and-egg problem. Is it possible to order the X-Carve and use it out of the box with a Dremel? I have the 8220 if that makes any difference.
I dont know what setup you have but if still running stock you can do this easily
Sorry it looks like I was no help. just didn’t pay attention to what I read.
You may have to order a spindle mount and shim the dremel. You should be able to use the dremel itself to make a couple decent shims, if needed.
