how do i do a catch all tray of the state of ky help please
Just download a silhouette of the state of Kentucku and set the inside to pocket out how deep you want it the set the outside to cut around it.
i have the sihouette but not sure how to get the out side cut
Download it and do the pocket drawing then copy and paste it into another file and set it for the outside cut.
in easal
Yes just copy go to the bottom open another file page and paste.
ok i will give it a try
thank you
shouldn’t the pocket measurement be small
Load 2 of the silhouettes then make 1 the size you want the whole thing to be. Highlight it and make it an outside cut. Then take the second one and make it smaller to fit inside the first one with enough room for your outer wall. Highlight both and center to material. Then highlight the inner one and cut to a depth you want as a pocket.
It will also work better for you if you use a solid silhoutte instead of a line.
I’m trying i really appreciate the help
If you can not get it let me know when i am done running the laser i will bring easel up and draw it for you.
thank you
nope can’t figure it out
got it thanks i was trying to fit all the cuts but that will work perfect
thank you so much
I used the offsetter app. Same as you all the points will not line up the other way.
i know it crazy
