Anyone have suggestions on what stepper motor I should upgrade to from stock ones? Upgrading to 9mm x & y axis belts from tbd cnc as well as tbd cnc z axis upgrade with 15mm belt.
Go with the next step up longer case Nema23’s, typically 72mm long. Make sure it will fit the Z as space is a little cramped here IIRC.
