Steppor motor issue (solved)
having some stepper motor problems i bought 4 new 280 oz stepper motors got it all wired up 3 work great except for z axis for some reason it runs then every now and then it will run then lock up and whine but its not consistent im providing a video any help would be greatly appreciated.
i was just holding it down so it wouldnt fall off that doesnt contribute to it not working
Did you try that motor on a different axis?
The feed/acc. rates may be too high for unloaded running.
If you try the Z motor on one of the other drivers (X for instance) is it the same or running good?
If good mount it up and try the feed/acc. again.
i know i nvideo i have it sitting out but i first noticed it when it was hooked up with the z axis doing a dry run.i switched the x axis and z axis and it runs better no jerking seems way slower maybe ineed to change grbl settings on z?not sure why its full speed on z
$132=100.000
$131=790.000
$130=790.000
$122=100.000
$121=500.000
$120=500.000
$112=1800.000
$111=8000.000
$110=8000.000
$102=188.976
$101=39.683
$100=39.650
$32=0
$31=0
$30=1
$27=1.000
$26=250
$25=750.000
$24=25.000
$23=3
$22=1
$21=0
$20=0
$13=0
$12=0.002
$11=0.020
$10=115
$6=0
$5=0
$4=0
$3=4
$2=0
$1=255
$0=10
ok
$132=100.000
$131=790.000
$130=790.000
$122=100.000
$121=500.000
$120=500.000
$112=1800.000
$111=8000.000
$110=8000.000
$102=188.976
$101=39.683
$100=39.650
$32=0
$31=0
$30=1
$27=1.000
$26=250
$25=750.000
$24=25.000
$23=3
$22=1
$21=0
$20=0
$13=0
$12=0.002
$11=0.020
$10=115
$6=0
$5=0
$4=0
$3=4
$2=0
$1=255
$0=10
solved just had to change 112-1800 to 1400
