Steve's Projects
I used Carbide create and did it in 3 passes.
I loaded the EGA as a jpg.
Created an outline of the EGA 1/4" outside the jpg.
Created another outline 3/8" outside the first outline.
Pass 1 Cut the pocket using a pocket using a 1/4" endmill .400" deep on the inside of the first outline.
Pass 2 Used VCarve tab to carve the EGA using a 20 degree v-bit. Starting depth was .400", max depth .500"
Pass 3,last pass, was to cut-out the tray using a 1/4" endmill on the outside of the 2nd outline.
I used 8 tabs and I also taped everything down with some good double-sided tape.
I used a handheld router to round-over the bottom edge and cut the relief for the base.
I had planned it to be a catchall tray for my friends dresser, but his wife liked it so much it now hangs on the wall in their family room.
USMC Catch All.c2d (1.1 MB)
If looking to make many gifts easily think of the attached catchall tray I did for another marine friend.
It was much easier.
USMC Catch All with name-2.c2d (1.2 MB)
If anyone knows how I can improve on any of these please let me know.
I need to learn more.
Bill
Thanks so much do you have one for easel?
I don’t have any of the trays for Easel, I only have the free version of Easel.
And you need the Pro version for some of the bits I used.
Bill
A few new ones, the wall art measures 86" x 60". 8 pieces, each piece was tiled as two runs. MAde out of MDF and hammered copper spray
IMG_2189_1
Here is a picture of what I did thanks with your help.
Looks good I also have made that one in the past
IMG_2388
IMG_2387
IMG_2386
IMG_2392
Build in Easel, base cut on the X-carve pieces cut on the Glowforge
IMG_2487
IMG_2418
69265407716__7496A3F8-ED44-44D6-A558-67F579E0A61B
Like the cardnal - Here is another one I just got done doing.
Thanks and that looks good!
Some new ones, I use Easel on about everything so may be a little xcarve these are Easel heavy through the glowforge.
IMG_2542
IMG_2544
IMG_2563
IMG_2564
IMG_2565
69619985875__F9F60D79-932F-4FD1-8E64-9135BE5F7427
Love the mater
IMG_2596
IMG_2615
Great stuff as always Steve! May I ask how you painted the Bengals sign from you Nov post? Did you use a masking?
Base is cut on the X carve, all the pieces are cut on the glow forge laser. I use Rustoleum 2x then clear or satin finish. Who Dey I used paint pens 2 coats. The laser scores the areas and I paint up to the line.
Thanks for the compliment! Steve
New one
IMG_2632
IMG_2649
