Thanks! Here’s the finished product, just waiting on UPS to start assembly
Ron, I went to a local welding shop and they got some pieces of aluminum from their “scrap” bin. Fairly large pieces, too! I paid next to nothing for it and it cut beautifully on my XC.
Thanks Gord… that’s a great idea.
lol no, waiting on the two wide makerslides
Which one did you get?
Nice, based on the prusa.
Here’s the custom lift plates and the wide maker slides on the y axis all finished. When I get a little cash I’ll add the other v wheels and plates.
so the y axis wider maker slides, does it seem significantly stiffer?
Extremely stiffer
Really digging the y wides …
Good work on the plates! they look sharp!
They should really offer it as an upgrade, such a difference in rigidness.
Yes
Finally got around to installing my @CharleyThomas endplates … I was inspired by @BrianSaban with the wide Y axis that he added and remembered I had my old original X-axis rails (replaced with the newer wide one)… so, i thought to myself, why not add a few holes to the end plates and see what we can do … voila…
Unless I missed it somewhere, how thick do the Y axis plates need to be? In other words, what is the horizontal distance between the bottom extrusion and the Y axis rail? It seems some have used .250" plates, and some have used what looks like 1/8" steel. I was planning on picking up some 1/8" steel plate and making some brackets, just want to make sure I don’t need to use spacers.
C.j-
If you are willing to trim your waste board, you can use 1/4" stiffeners. I have also done 1/8" stiffeners for customers who don’t want to trim the waste board. My machine is a 750 with 1/4" stiffeners, and my waste board is around 26 7/8" wide.
If you want to take the easy way out, I sell 1/4" aluminum stiffeners on my website and can do 1/8" as well.
-Luke
okay, so I guess by deduction the gap between the rail is 1/8" That makes sense. I plan on laser cutting them out of 1/8th inch steel.
