Are you running the same file over and over?
Great Changes to this operation. Thanks guys. Also agree the spindle going to the top line of the cut for every tabbed event is very annoying and extremely time consuming. Glad to hear this is in the list to be corrected.
We have not seen the pausing. We donât believe itâs related to the reversing, so I created a new topic:
Thanks for the additional example, Kurt.
As Zach said, weâre moving forward with our larger changes that will eliminate all reversing issues and safety height lifts. That work is getting nearer to the finish line. We will make the announcement when itâs available. Weâre in the home stretch now.
moved to beta forum
edit
Good day , I know this is an old thread, but the problems discussed here is exactly what I am suddenly experiencing using EaselâŚ
I get a perfect cut, then when it reaches the tab depth for the âthrough cutâ, it reverse direction and slightly moves of the cutting path, ramming into my work piece few seconds after the reversalâŚ
This was not a problem in the past (few months ago), but at that time Easel did not reverse the direction of the cut when doing the tabs.
Is there anyway I can ask Easel to not have the reverse cutting optimization for the tabs?
