Why does the machine stop 1/2 way through carve?
My guess would be some type of electrical enterferance.
Thanks, I will check to see if I have an issue there.
Check your power settings computer might be going to sleep
Also could be from dust collector if you are running one.
Here are some suggestions:
That happens frequently do to electrical interference. Here are some suggestions:
Use a good quality shielded usb cable
do not have your router cable running along with your stepper motor cables
plug in your router, shop vac and any other ancillary devices into a different outlet as your controller
and finally. don’t have your controller plugged into the same circuit as a refrigerator, freezer,air conditioner or air compressor. (when the compressor in these devices first turn on it drops the line voltage significantly for a moment.
What software are you using tro send the gocode to your machine? Easel, UGS, PicSender, etc…
Easel
I had the same issue for a bit. Once I plugged my shop vac into a separate outlet it stopped. I now leave the outlet my machine runs on completely dedicated to the machine.
Joe
Joe4re,Were you able to restart where you left off or did you have to start from the beginning?
unfortunately i had to restart from the beginning
