Check out Fin Foil app. Can design and export files for machine.
If I wanted to set the middle of the fin 1 1/2 inches and tapered down 1/4 how do I make that taper effect. Im trying understand tapering. Thank you for the replying, i designed a fin on easel but have no idea how to taper down.
Within easel theres a list of apps by selecting the lego button on the left and then the app to kinda sorta add 3dish effect like the taper is calle super gradient generator and it will probabily take a bit of guessing and checking to come to a usable solution.
& You may need to make another copy of the original design and modify the shape a bit so the gradient only does the areas you want it to…
Thank you I will try it out.
