I converted a jpeg to an SVG format. But when I put the SVG on a project it doesn’t
show on the preview board. Any ideas??
What bit do you have it set for? set your bit to a V bit see if it shows, the detail is likely to fine for the bit that is selected, Easel will only preview what the actual bit can cut
