In previous versions of Easel, when adjusting tab settings, it could be adjusted to a point above the material, not just a point within the material itself. When cutting foam, I want to use tabs that are the full thickness of the material, PLUS about 2 or 3 mm, to prevent possible snagging, BUT, after a recent update (this year, I believe), tabs can only be adjusted up to the material thickness setting, and not above.
Is there a work around, or a way to restore this feature?
Thank you!
Tony
