Is it possible to decide the position where Tabs can be on a carve?
there are some places where you would rather not have tabs especially on very hard materials on which sanding can be tricky!
What software are you using?
I use vectric desktop and the answer is yes, they can be added, moved, or deleted as you see fit.
In Easel you can slide the tabs around as seen fit
Thanks Haldor
#WannaBePro-Tip - When working in EASEL, PIN your outline prior to dragging the tabs around. Sure, there’s always CTRL-Z to undo an unwanted move, but who has time for that…
{:0)
Brandon Parker
