Very newbee question
Is there a difference between a bullnose bit and a tapered bullnose bit?
If so does inventables sell a tapered bullnose ?
Yes there is a difference.
One is straight and the other is tapered.
Take a look here.
I buy quite a few from them.
@ChrisAchtschin Ball or Bull? Two different things.
Regardless, the taper allows for a thicker shank (stronger) on a smaller tip (more detail).
My mistake it’s a ball nose bit. It is used in a vectric project/tutorial making a 3D golf award. I have a 1/8 ball nose that i got from inventables. I don’t see any tapered ball nose bits on the inventables store.
Lots of info here with pictures of the database setup in Vcarve. Link I use this tapered ball-nose all the time. Link
I made this tap handle for my customer.
If you want this kind of detail, you will need a tapered ball nose end mill like David shows.
Looks nice!
How did you make the handle? Did you do this in easel with a g-code, or use a different software?
I use Vectric Desktop software exclusively.
I have never used Easel because its tied to the internet.
Go to the Vectric website, and you can download a full version for a free try out.
Jan,
same here, can’t stand easel for same reason.
thumbs up on your project .
