Is there any way to exaggerate the Arc Edge of a piece of text using the ‘Text Effects’ button in the Shape tab? I need a piece of text that is straight across the top but the bottom needs to conform to a circle that is below the text. When I use the Text Effects, it barely arcs the bottom.
Look at the APP Path Warp. Set you text. Then combine it with a dot or something. Then remove the dot this way the text it is not actually text anymore then you can use the APP to get the affect.
Thanks Steve!! That trick allowed me to do exactly what I was attempting! Thanks again!
