Hi I used the text tool to add a house name on a project.
I am using a 2mm slot cutter the text in easel is perfect but when it cuts I am just getting a series of dots any ideas ?
Without knowing a little more i would say your bit is to big. Try a smaller bit and run the simulation before you change the size and after and see what you get.
Cheers you where spot on bit was to big .
