Text on text sign help
Can someone point me in the right direction. I’m wanting to make a text on text sign but use a ball nose bit to cut it out. I’ve already designed sign in aspire and cut it out with v bit and end mill but would like to try ball nose but not sure how to switch it over. And advise would be greatly appreciated! Thanks p.s. I’ve been searching for a while now but no luck finding how to do it.
It should just be a matter of telling Vectric Aspire that you’re using a ball-nosed endmill — if that’s not an option there, F-Engrave does have support for cutting text with a ball-nosed endmill.
So i was able to pick ball nose but the times were way too long. Ill take a look at F-engracve. Thank you
