Inventables Community Forum
Text Stretching
When I type in Easel it stretches the text, does anyone know why its doing this?
Thanks
Russell
@Ben-Saks maybe a fault of the fix this AM?
Russell. Not sure if its related to this rollback to yesterday’s version ?
I am not able to replicate this issue - it is not likely to be related. @SethCNC were you able to replicate this?
No, sorry I was in a rush out the door and happened to see this right after your post about the resolution to the other text issue and thought they were connected…
I think I can force the issue by changing the text box dimensions. Forcing it to be short and wide…
But I know Russell would have noticed if that was what caused his issue. :flushed:
I have a video that I took with my phone.
I can’t really see the stretching that is indicated in the first post, but that text is 2" tall and 20" wide from looking at the grid in the image.
All I see when I type text in is that the bounding box is slightly shifting things as I type, but not really stretching anything.
{:0)
Brandon Parker
If you look at the R you can see it get wider with each letter I type. The more I type the wider it gets.
This is what it looked like when I typed my name
Oh yeah, I am not disagreeing with you on that front. Something strange seems to be happing on your end, but I just can not get it to do the same thing on my end.
{:0)
Brandon Parker
I just tried it on another computer and it works fine so its just this computer, using text works fine in my other programs so its only Easel.
Russell
Do you have a cat or a two-year-old running around? They are notorious for finding extremely secret special key combinations that perform unicorn magic on computers! :grin: :joy:
{:0)
Brandon Parker
I do have a cat that started sleeping in my shop a few months ago, I had to put things around the CNC to keep her off. I would come in and she would be on the spoilboard. Now she has been sleeping in my computer chair so its a possibility that she has walked on my keyboard. :flushed: :joy:
Problem solved…
{:0)
Brandon Parker
I tried it using Internet Explorer on this computer and it worked fine so it has to be a setting in FireFox. I use FireFox on my other computers so I know it works. This is the computer that I design on in my shop. Maybe someone knows how to correct this issue in FireFox?
Thanks for your help
Russell
EDIT: I went into FireFox and restored to factory settings, all is good.
Thanks
Russell
