The problem of light vibration on the x column
The movement on the x column, there is a very slight vibration, does it affect the work? Please answer and what is the solution to discover the malfunction?
If your X axis has vibration have you checked the V wheels? If they’re loose you need to tighten the eccentric nuts.
Russell
https://x-carve-instructions.inventables.com/1000mm/step2b/4adjustablevwheels/
Edit: This thread is about the X-Carve Pro, never mind
Does the Pro have V wheels?
I assume the OP has a Pro as this on the Pro category.
I am think possibly too aggressive on the cut settings.
:thinking:You’re right, I need to start looking at what section this is in. :anguished:
