I can do a single bit cut but when I try and do a 2 bit cut, 1 rough and then 1 detail, I get the following:
As far as I can tell,I am following Inventables guide lines in doing a 2 bit cut. Why am I getting this error message? I can do the rough cut by itself, which is a simple Christmas ornament, but when I try to add a name and year to the ornament, I get this error message.
But I agree with Wayne, it sounds like the design path (border) is too narrow for your selected tool to fit inside. You can quickly test this by stating a very thin bit diameter / or V-bit as it will fit inside “infinite” narrow paths.
Here is a link to my project. Easel - Circle Ornament Tree Paige
As you can see I am trying to create an ornament, cutting it out with a 1/8th bit and I want to also add the year and name on it using a smaller bit, .8mm.
Basically, Easel is trying to use the detail bit for everything. It is using the detail bit for your cutout, and the text is not large enough for the 1/8 inch bit to be able to do any roughing.
You probably want to split this into two cuts: 1) The text with your detail bit, then 2) The cutout with your larger bit.
That is what I have been trying to do. I have been following instructions I found in this forum. Only the Detail is supposed to be using the smaller bit.
The two stage carve is for when you want to hog out a large area with a larger bit and have a small bit do all the edges. But that doesn’t work for a cutout, it ends up using the detail bit for the cutout, which usually isn’t ideal. I generally separate my cutout into a separate work piece and do it separately.
