There is shift in my job
I have problems in my cnc, if I want to carve circle, it is starting good , but after many steps the bit stick in the material, and changing the bath, and damage the circle, I see when I start spindle, the z axis move small steps, and the green led flicking, this happens with easel, I try to change to vcarve and see what happens.
Bath?
You’ve got bad spindle. Call Inventables, they will cover you.
