I’m going to be doing a lot of engraving and sign making. A little pricey but seems like just about everything I need. Anyone have any thoughts?
http://www.toolstoday.com/p-6226-8-pc-cnc-signmaking-starter-router-bit-collection.aspx
I have seen on here people using the insert v bits with good success. Has anyone used the In-Groove system that comes with this set before?
http://www.toolstoday.com/p-6009-in-groove-cnc-insert-engraving-tool-body-replacement-solid-carbide-insert-knives.aspx?variantids=10564,0
We have tried it, but it was not balanced good enough for our 45,000 RPM spindle. The small tip would wobble and cut a wide path.
Do you think it would work with the Dewalt 611? Thats what I am currently using. 16,000 rpm.
A couple of the tools in the first set listed are 1/2" shank which would be unusable in your DeWalt 611. It might be cheaper to purchase just those bits you can use, as separate items.
My bad. I linked the wrong set
The second link you sent is good tool for different replacement knives. I have 3 different knives for it. Works great. Didn’t have problem for vibration on either Dewalt or Makita. Using speed 4 on both. Two cons… 1- Loud noise spinning, 2- 30 degree one dropped to oak work surface while changing the bit, dives into wood because it is heavy tool and sharp tip, then I didn’t pay attention picking up, broke the tip of it. But general speaking, great tool to have.
