Three Easel Suggestions
  1. Do not select outline when selecting objects inside outline.
    Example: Create rectangle, select outline, outside, place two objects inside the rectangle, select the two objects using the mouse with left button/drag, the rectangle is selected also. I do this when I need to move the objects inside the rectangle or need to align them.
  2. Provide a way to change the autosave feature. On a slow machine or slow internet connection, it disrupts dragging objects. I would prefer an autosave when I hit the carve button and/or at a certain interval.
  3. Provide feedback (ā€œGenerating detail toolpathā€ with progress) during detail bit toolpath generation. If the carve is highly detailed, this step can take a while and nothing is displayed on screen - the window is only disabled. The first time this happened, I thought my computer had locked up.
Thanks!
Regards Steveā€™s number 2 suggestion regarding ā€˜autosaveā€™, I would prefer that no saving occur until I tell it to save using a new entry in the ā€˜fileā€™ menu. That way if I want to revert, I simply reload the file. At the moment, I have to make copies and then keep careful track as to which file is the latest with acceptable changes. I also worry what happens if an autosave fails in the middle. Likely my file would be wiped out.
How about they allow the use of probing commands to zero your machine with a touch plate in Easel.
Yes Charley! I knew there were four things I wanted to suggest.
Four: Use of probing commands to zero your machine.
A while back I sent a msg to Zach Kaplan about this. He said that the Easel gurus were looking in to this but I havenā€™t heard anything since.
I only have one voice but if enough people started asking then I am sure that they would act.
ā€¦ and number 5.
An Easel version number with changelog.
