Hi -
I have started a project where the outcome will be a circle that is 48" or so with 1000 holes drilled. I have a work space of 28x28 and don’t have my pro account activated (yet).
I think I have been able to have all the drill holes sectioned into four parts, but really struggling with how I’d cut out the 24x24.3(ish) squares. I have the lower right corner cutlines figured out - using some squares to mask things out, but can’t figure out how I’d do the other three squares. Then I learned about tiling, but I can’t really cut just 24x24 perfectly without messing up the drill so not even sure if I were to use tiling if I would be successful when I get to cutting.
If someone(s) can take a peak at the project and let me know if there are some ways to best achieve this it would be appreciated. You can also see that I had to painstakingly align 1000 drill holes and think I did it the best way possible with circles and lines intersecting then trying to centre the holes.
Any ideas are appreciated - thanks!!
Ryan
