How do I disable the tiling feature when it not needed.
Go into machine> edit machine and update your work area.
If the workpiece size is over the work area size then itll automatically turn on tiling…
You can also turn off tiling by clicking the material dimemsion at the top right and toggle it off in there, but it shouldnt be on if the work area is set right and workpiece size is set within the workarea peramameters.
