BobCnc’s Axis are reversed. The “long” axis is X and short is Y. Anyway to still use Tiling in feature?
You’d have to use manual tiling (not easels built in feature)
There are older videos on YouTube (early 2020 and older) that show this, basically you cover the section you don’t want cut using a rectangle set to depth, then carve, then move the design and move the rectangle to cover the part already carved…
Or re-flash the arduino grbl code to put x and y back where they belong, there are other forums covering this, but the last I heard Bob will not provide any assistance to users after they do this change and will not help anybody perform this change.
