Thanks Phil, always love seeing your videos, they have been a great source of guidance, especially when I 1st started reading/watching. Yeah, time is hard, but thankfully I insulated the ceiling in my garage and my twins room, and I switched over to a Vacmaster VF408 shop-vac recently from my Ridgid and it dropped the noise in my garage easily by half (Best $60 I have spent), so I am able to run the machine at night.
-Mike
Mike,
Funny that you mentioned insulation as this is a big to do for me soon. My garage is my workspace and here in Western NY winters suck and working in the garage can be difficult at times. Iām starting with getting the garage door insulated and the spring adjusted to handle the added weight and thatās happening next week.
After that Iām either going to do the walls (only two need insulation) which already have dry wall up so I either take it down, insulate and rehang or do blown in cellulose or I can go to the attic space and lay down rolled insulation or do cellulose?
Not sure where you live Mike but has the insulation helped with temps where you are or is it mostly for noise?
The garage is where my Xcarve is going to go so I would like to try and keep the temps up as long as possible when Iām out there.
For anyone in the north with the Xcarve in the garage would you mind sharing how you and the machine are doing in the cold? Or share how you insulated and keep your garage warmer?
Hey Ben,
I ended up doing mine for as much noise containment as possible, as I live in Arizona. So, while you have the brutal winters I have the brutal summers. If I stay in this house another summer I will be seriously considering a mini-split A/C unit, but so far I have sucked it up every summer and still been out there like any other day (time allowed).
FYI, my garage walls were already insulated, only did the ceiling, but for the interior house walls we cut 4" holes between all of the studs and then blew it in and recovered/textured/painted after. Was a fairly quick processā¦however this was before the kiddos came lol
-Mike
Thanks Mike! The more I read up and watch things I think the blown in is the way to go since the dry wall is already up and it looks like my wife (maybe brother) and I could handle this as a weekend job. I have heard the machines are usually free to rent as long as you buy the cellulose from them.
Thanks for the information! I really appreciate it!
No problem at all, happy to help. One other word of advice on this, is yes, at least here in AZ the machine rentals are free at Home Depot if you purchase 10 bags of the blown in insulation, but here is a nice tip, they give you a sizable contractor discount at 30 bagsā¦I only needed 15, but the guy told me to buy 30 and then just return what I didnāt end up needing. This allowed me to get the machine rental free and then a discounted cost on the insulation, and had no issues returning the ones I didnāt use.
P.S. My fault for driving this thread off-topic lol, apologies.
I was thinking the same thingā¦ no way that cutting board was made in an hour including milling the wood and gluing up.
I have two items that I have produced in the shop that I could sell many but does not make sense. A personalized bottle opener with wood engraved handle that I sold for $30 , and a tool caddy that is made with $15 dollars worth of HDPE material and sells currently for $100ā¦ Its all just for fun if you cant make at least $50 an hour in the shop.
Are you talking about how did I cut it that fast or how did I design it that fast?
Maybe doing some craft shows ? Get your name and product out there
Hey Rick, what material did you use for your door sign? Weāve tried to use 7mm and 1/4" baltic birch plywood (which looks like what youāve used in your picture) but the material has ended up breaking across the thinner designs, so weāve more or less given up on making these types of signs for the time being.
Sorry didnāt see your response sooner. I used revolution plywood which I want to say is around .201 they make hard maple 1/4 plywood which I usually enter in at .22 what are you having problems with it breaking? I think it might be how your doing your tabs, just guessing. Typically anything over 2 square inches I do at least 2 tabs per negative cutout evenly across from each other if you donāt keep those negative cutouts stable theyāll usefully chatter around leaving a saw tooth looking cut or break. Afterwards I use a multi tool(random oscillator) with a really narrow(Ā¼"toĀ½") blade or a Rockwell bladerunner 2(the one that can mount on the wall) if you remove the arm you have unlimited capacity and I would almost say itās made for cutting tabs.
Good info! We may have been using a straight bit at the time, not certain though. My wife has been commanding the x-carve and Iām not certain what she was using. We may have just have some bad luck with the plywood we used, however it seemed that smaller sections of wood (where the width would get below 1/2") were just too fragile and would crack and/or break in multiple sections. I see people use 1/4" plywood all the time though and theyāre successful with it, so clearly weāre doing something wrong on our end or using the wrong bit.
Not sure how you are clamping your source material but, if you havenāt tried the glue/tape method this may offer additional support needed.
@DanielMiller. Check out my project page here on the forum. I show the glue and tape method and how I hold down my projects. Maybe it will help you
Thanks Phillip! Love your youtube channel! When my wife was just starting on X-Carve a couple of months back, the first thing I said to her was ācheck out Paw Pawās intro videos on youtubeā!
Iām fond of using hot glue, though my wife is more fond of using tape. Weāve had VERY mixed results with tape, though. In general, weāre using double-sided carpet tape, which has been recommended numerous times. Itās super sticky, which is great for thicker boards. We havenāt had a lot of success using it with thinner boards and plywood because of how sticky it is. The other issue is that we canāt find a good basic double-sided tape to use. Of the ones weāve tried and seen recommended, I find that it doesnāt hold well enough, and boards will get whipped around the waste board. As a woodturner myself, this is something that is actually preventing me from wanting to use double-sided tape for securing bowl blanks to waste blocks as I see a lot of woodturners do because Iām afraid it will send a bowl flying across the shop!
Blue painters tape and super glue is my go to method. Works well for big and small projects. Never tried the double sided tape or hot glue. Iām sure each has their place. I hope you find what works best for you
Thanks for everyone sharing their experiences and stories. Ive been heavily debating on creating a etsy store merely for the ease of people creating orders and seeing offered products. Still on the fence though and might look for something else.
Figure what makes the most sense when you want to sell a item (wood custom sign) but also have different options and finishes to check off.
Many of us want a self sustaining workshop, and income from our passion. The one thing I see most, as a person that has had and sold several businesses, is the fact that almost no one does a full on business model before starting a new business. We start with the idea, and run with itā¦If a person sits down and writes out a firm business model of what we want to accomplish, and where we want the business to go, pricing, inventory, rent, tools etcā¦it makes the process easier to see in the long run.
Hi Lance, Iām Mark and new to CNC. My question is how do you keepthe letters attched to each other to make a name sign?
How did amazon handmade work out for you?
